Door catch source?
Posted: Wed Apr 20, 2022 2:57 pm
by edidin
Anyone know where one can get new ones of the dual roller/spring catch fitted to the strut of a 120 to hold the door open?
Re: Door catch source?
Posted: Wed Apr 20, 2022 3:25 pm
Try Home Depot. That's off a 1950's vintage kitchen cabinet door.
Posted: Wed Apr 20, 2022 4:13 pm
by 6277
That will no doubt work, but the proper part is a strap that fits around the strut. The strap has "stud" on the end that pokes into an opening on the bottom of the door. Inside the hole is a friction catch that captures the stud. Check page 20 of the parts manual.
Posted: Wed Apr 20, 2022 9:14 pm
by edidin
Thanks to both. After posted realized had seen as a kid on our old 1950s steel kitchen cabinets. Stock is the opposite apparently - catch through a hole in the door.
Posted: Thu Apr 21, 2022 8:06 am
I have a bucket full of the catches. Free if you pay postage and handling
The strap is easy enough to make.
- door clips.jpg (290.07 KiB) Viewed 4137 times
Posted: Fri Apr 22, 2022 11:36 pm
by meloosifah
I could use a pair of those door catches if they are not going to be used! Both of mine are worn out.
Posted: Sat Apr 23, 2022 6:47 am
meloosifah wrote: ↑Fri Apr 22, 2022 11:36 pm
I could use a pair of those door catches.
Sent you a private message.
Posted: Sun May 01, 2022 6:25 pm
by greenwr400f
John if you have any more of those catch's I need a couple please.
