Polyfibre Cleaning Product
Posted: Thu May 26, 2022 4:04 pm
by 6277
I recently removed some decals from the underside of my C-140 wings. There is some residual glue from the vinyl decals that I need to clean off. Can anyone recommend a cleaning fluid or some way to remove the residual glue w/o damaging the paint or the fabric. The fabric is poly fibre and the log entry states both wings were covered with Poly-Fibre IAW STC SA1008WE.
Re: Polyfibre Cleaning Product
Posted: Fri May 27, 2022 1:22 am
by 4004
Test a spot with WD40 and work it some, give it some time, and clean off oil residue with soap and water.
Polyfiber and polyurethane paint are tough - don't think WD will hurt either. 2c
Posted: Fri May 27, 2022 11:57 pm
by 6478
Goo Gone might be worth a try too. I've never used it on the plane but have had good results on many different surfaces with it.
Posted: Sat May 28, 2022 6:09 am
by 6277
Tried both WD40 and goo gone. Neither worked very well. Just ordered some Poly Fibre paint cleaning fluid. Thanks.
Posted: Sat May 28, 2022 7:23 am
What kind of adhesive is it? When you say "decal" I think of the water soluble ones we used to use on model airplanes...
One other thing you can try is vegetable oil.
Posted: Sun May 29, 2022 2:14 am
by 4004
One more FWIW, curious what the decals were for? Try calling "Aerographics" the decal people and ask if they have any suggestions, that's why I ask about the decals, possibly something they suppled . They're good folks, I ordered new "N" numbers from them in the recent past for another aircraft. Also try a bit of lacquer thinner in a test spot, again I don't think it will affect the two coatings I mentioned earlier. Inflation, price went up, 4c.
P.S. A dab of 100LL, if you haven't tried already.
Posted: Sun May 29, 2022 7:13 am
...again, being careful with trying a small spot, you might try Wally World carb cleaner. I use it for everything except salad dressing and eyedrops
Mac
Posted: Sun May 29, 2022 10:04 am
by 6277
OK, the vinyl decals were installed by the previous owner who was a missionary pilot. They were religious in nature and able to be seen from the ground. In retrospect I should have taken them off twenty years ago. No excuses offered and constructive criticism accepted. The substance that is left after I peeled the vinyl decals off is hardened now. The fabric is still in excellent condition. I will try the Poly Fibre fabric cleaner when it arrives.
Posted: Mon May 30, 2022 10:09 am
by a64pilot
I would NOT try carb cleaner or Acetone or other really aggressive chemicals.
If you must, try some on a Q-tip to see what happens, i’d expect carb cleaner to dissolve the paint.
Posted: Mon May 30, 2022 5:43 pm
Yeah, I dissolved some slider bushings in the forks of an old Triumph by accident once...
