Gear leg inspection, cleaning, priming etc.
Posted: Sat Jun 11, 2022 1:20 pm
by 8024
Good afternoon all:
I am looking to see if anyone knows of a good shop(s) that clean, inspect, measure, re-shot peen, and primer Cessna spring landing gear. I have 2 sets of C-140 and a set of C-172 I'd like to get inspected. I heard there was a shop in Minnesota (I'm in Wisconsin) that does this but I haven't found any information. If you could let me know of a shop(s) that do this with name and location (phone number would be great too if you have it), I would greatly appreciate it.
Also, if anyone had this done and knows an approximate price, that would be good as well. I run a small salvage business so I have to see if it's cost effective to refurbish prior to sale or sell as is and just offer a refund if they are no good.
Email is best for replies please: smokinrivetairparts@gmail.com
Thanks in advance!
Todd Littfin
1947 C-140 NC4112N S/N 14025
SLOW restoration in process
Re: Gear leg inspection, cleaning, priming etc.
Posted: Mon Jun 13, 2022 4:13 pm
by a64pilot
I’m not sure you would want to re-shot peen them.
It’s my understanding that 140 legs break at the hole the step bolt goes through, cracks start there and propagate.
I think if you want to really ensure good legs that maybe mag particle inspection or eddy current and polish out the holes.
However the crack growth propagation in high strength steel is very rapid, so if you found a crack I think it would be pure luck.
I assume but don’t know that they were only peened on the bottom?
15 years or so ago I just polished out my holes and coated the bolts in Par-Al -Ketone. I believe original steps were riveted on and not bolted?
On edit, we’re they originally Cad plated? I imagine they were and would re-shot peeing remove the Cad plate?
Posted: Fri Jun 24, 2022 9:42 am
by 8024
Hi Jody:
Thanks for the information. Yes, I believe they are only shot-peened on the bottom. Mostly looking to just get cleaned up and primed to prevent more rust and degradation on the ones I would like to put up for sale.
I'll do some more digging to see that I can find.
Kind regards,
Todd Littfin
Posted: Fri Jun 24, 2022 10:56 am
by 8102
Attached is a excerpt from the Cessna 100 Series 1962 and Prior Maintenance Manual in regards to corrosion control on landing gear.
Gregg
Posted: Sun Jun 26, 2022 10:54 pm
by phil123
You might give these guys a try they would know the proper repair techniques. https://tlgw.aero/landing-gear-reconditioning
Posted: Wed Jul 20, 2022 12:12 am
by 8024
Thanks Phil--I will do so--thanks for the lead!
Posted: Mon Jan 16, 2023 10:09 am
by 6183
Found this interesting video from our friends on the Cessna 170 Forum
https://www.youtube.com/watch?v=O8e_f6SWdcg
Posted: Mon Jan 16, 2023 12:56 pm
6183 wrote: ↑Mon Jan 16, 2023 10:09 am Found this interesting video from our friends on the Cessna 170 Forum
Thanks, Mike -- makes it plain and simple that there's no wiggle room if gear leg is "bent". Kinda related...I do recall an early SN 170 that I flew and was always impressed( :o ) with the "flexing" of the gear legs, but they were not bent. After "all of these years" that 170 is still airworthy. I believe those were the same legs that they used on the 120s/140s except for the "step hole". They're well engineered and tough, but a really hard landing(s) and/or cracks @ the step "holes" can make them junk...or worse. Good info.!
Mac
Posted: Mon Jan 16, 2023 2:20 pm
by edidin
The cure for the C170 duck waddle gear is to put early C180 gear on them.
Posted: Mon Jan 16, 2023 7:42 pm
edidin wrote: ↑Mon Jan 16, 2023 2:20 pm The cure for the C170 duck waddle gear is to put early C180 gear on them.
Yep. I understand that the PPonk beef-up kit is a good upgrade, too. Still, it's reassuring that our old gear legs have really stood the test of time, especially when well maintained and not abused (...inadvertedly or on purpose :roll: ). Mac
