C-140 Flap bellcrank wear at spring connnection
Posted: Fri Aug 26, 2022 6:28 pm
As the title says, those long springs that keep your flaps neutral up behind the headliner have caused some grooves in the bellcrank. I read a possible repair using AN115-8 cable shackles, but at $15 a pop times 4 I thought I'd see if anyone had another acceptable repair. Something I need to address for next annual.
Illustration 49-7, part# 0411339 Bellcrank Assembly/Flap
Re: C-140 Flap bellcrank wear at spring connnection
Posted: Sat Aug 27, 2022 11:33 am
Dave, I think it may have been John Cooper who suggested that maybe welding up the area and re-drilling holes might be an acceptable repair(?) and alternative to David Owen's neat fix and excellent write-up. If I'm seeing it correctly, though, and if the springs are also worn, the addition of the cable shackles may provide a bit of tolerence for shortening/re-arching the springs, 'though minor spring length adjustment may not be critical(?). Aircraft parts and pieces seem to always even out pace runaway inflation, don't they!?
Mac
Posted: Sat Aug 27, 2022 11:51 am
How about tailwheel spring clips, $3.95 each?
Posted: Sat Aug 27, 2022 11:58 am
On my way to the hangar now to investigate, very clever!
Mac, yes, I will check the spring ends, if I find some wear then yes we'll 'adjust' them. I suspect if I use the spring clips I'd have to shorten the springs anyway. Thanks all!
