Polyfiber silver?
scotts97385
Polyfiber silver?
I am in the first stages of planning a restoration of a 120 and will be recovering the wings. I would like to get the wings as close as I can to the stock silver from the factory, is Poly Spray (the silver step after Poly brush) close or will I need to top coat with another silver?
- Name: Edd
Re: Polyfiber silver?
Since no one has responded, where will one find the color of the OEM stock ? It possibly has been on here in years past. If you have that color, I will be happy to compare it with the Poly Spray. Of course the PS does not have a glossy finish. IIRC most of the OEMs were not painted but just had an accent stripe. First introduced to the 120/140s in 1946 so OEM memory begins to fade.
FWIW
