Weighing the 140
Posted: Tue Jul 17, 2018 8:54 pm
I searched the POH and library for weighing the 140. Seems as though my IA can only locate the original W and B from when it left the factory. Certainly there must be a procedure out there. I know that one must remove the fuel and I assume that it must be in the 3 point stance and be drained through the gascolator on the firewall. But then, how much fuel is left in the tanks?
To weigh it, it must be in the flying configuration, i.e. level, using one of the skin parts (just don't know what it is called}
Any help would be appreciated. We already weighed the plane but afterwards, I was able to drain a lot of fuel from the tanks so I am not convinced it was correctly done. Would not even question it except that the weight came out over 1000 lbs but I want it to be accurate.
