Window latch measurements
lostcoast120
- Name: Andrew B
Does anyone have plans/ measurements for window latches? I want to make a set but don’t have anything to go off of as my 120 is missing them. Thanks
8224
Re: Window latch measurements
Andrew, I just made a set for the left side of my 140 and plan on making a set for the right side before it gets hot again. Send me your address and I will make paper templates of each part and send them to you. By the way, I had a set of old worn out aluminum ones (original) and I used them as patterns. They would not work! I changed the geometry and made ones that work. Mine are made out of light gage, about .020 mild steel. The set I ended up work perfectly. I now have 4.1 hours on my newly rebuilt 140!
Steve Hawley
Hluther205@gmail.com
Steve Hawley
