Cabin heater cable
Posted: Fri Nov 11, 2022 6:18 pm
by 7130
Apparently the cable that activates cabin heat is broken.
Any tips for replacing it?
C140 SN 9907
Re: Cabin heater cable
Posted: Sat Nov 12, 2022 12:19 am
by beaverbill
I have "heard" that a NAPA part number 731-1121 choke cable will work for this sort of thing. May even be able to leave the old outer cable in place and just pull out the inner wire with the knob attached. See if the replacement wire will slip inside the old housing. Or just change out the entire push-pull control cable. Hope this helps. Bill
Posted: Sat Nov 12, 2022 1:10 am
by 7130
Thanks Bill!
Posted: Sat Nov 12, 2022 9:40 am
I was able to find a control with the same diameter wire (which was broken) (the old one, not the new one...) and silver solder the new wire to the old knob, for authenticity.
Posted: Fri Nov 18, 2022 7:37 am
by 6898
McFarlane has great products
