Stromberg Carburetor Inlet Screen
Posted: Thu Dec 01, 2022 11:48 am
by 6795
Can someone explain the proper procedures to remove, clean, and re-install the carburetor inlet screen.
I thought this info was posted here but can't find it!
Re: Stromberg Carburetor Inlet Screen
Posted: Thu Dec 01, 2022 12:14 pm
by tonycondon
Access to the screen is through the big brass hex nut 90 deg offset from the fuel inlet. Cut safety wire and unscrew. The screen is right there. No torque specified for reinstallation, just tight with no leak.
Posted: Thu Dec 01, 2022 1:47 pm
by 6795
Thanks Much!
Posted: Thu Dec 01, 2022 2:02 pm
There is a copper washer under the plug. It might make sense to anneal it while it is out.
