Metal Wing STC + Drag Wires?
Posted: Sun Jul 09, 2023 8:25 pm
Hello All:
My 120 has the SA4-89 Wing metalization STC but oddly two of the drag wire sets (inboard and outboard) have been deleted.
I have searched the forums back and forth and haven't found anything other than Bill Rhoades made some sort of post a long time ago that I cannot find that states that you can delete out the drag wires without compromising safety (I've read the wing STC PDF a dozen times)
Does anyone know where to find this technical insert? Any way we can find any of the drawings for any of the STCs?Some STC’s must have called for the removal of the steel drag wires. If the fabric was removed and then
the drag wires removed, you immediately had a wing a bit limber, spaghetti-like. One owner at least
confirmed that his is twisted and lumpy from such a likely cause, but the plane flies like the others anyway.
From our supposing, we believe that the drag wires should have been left in to retain the wing shape at
least until either the top or the bottom metallization was secured to the structure and then it would have
been safe to remove the wires. They weigh about 8 pounds. Bill Rhoades published the information in one
of the Technical inserts to the newsletter about why it was okay to remove the wires when the wings were
metalized. I can still see mine, not all of them, so the weight change would have been less than noted if
they had been removed.
