Torque values
Posted: Thu Aug 03, 2023 4:50 pm
				Greetings,
I am putting the wings on a 47 C-140 and wanted to see what torque values are being used for the wing and strut attach points. As you know, the typical reference is the standard torque chart in the 100 Series Maintenance Manual, which specifies a wide torque value range for dash 8 bolts in shear applications. My question is what values are typically being used? 75% of the range? Top of the range? Allowable minimum value? Any insight would be gratefully received and appreciated.
TH
TH
