From Metal back to Cloth wings?
Posted: Fri Aug 18, 2023 9:55 pm
by publius
I am working on a 140 restoration project. It was converted to metal wings at some point. I am thinking about going back to cloth wings.
What is your opinion? Mistake?
What issues could I run into?
Re: From Metal back to Cloth wings?
Posted: Sat Aug 19, 2023 10:13 am
Do the wings have the OEM drag wires? (...believe some STCs may have removed?) If not, their availability may be at issue. Also, fabric attachment...OEM clips may not be available and, if they are, are the original clip holes OK? If clips can't be used, there are STCs for screws and pop rivets...but that's still an issue to consider. There may be other challenges but it is doable and definitely has been accomplished & maybe someone who has done will still wade in with advice. Keep us posted! Mac
Posted: Sat Aug 19, 2023 10:56 am
I'm told rib stitching (Stits?) is an option also, but someone is going to have to evaluate the condition of the ribs.
Posted: Sat Aug 19, 2023 11:07 am
Here are links to two other threads that touch on restoring metalized wings to fabric:
viewtopic.php?p=916#p916
viewtopic.php?p=205#p205
Posted: Sat Aug 19, 2023 6:27 pm
I went back to cloth wings. No regrets. They've held up nicely over the past 24 years(almost always hangared) and the weight reduction and better airfoil is appreciated.
Posted: Sat Aug 19, 2023 8:41 pm
by publius
Thank you everyone for the responses. I have decided to go back to cloth.
I appreciate your input.
