Aluminum Fuel Tank Cover
Posted: Sat Nov 04, 2023 10:13 pm
Hi All
I am interested in adding an aluminum fuel tank skins on a fabric wing 140. It looks like it should be straight forward structurally. just add #8 platenuts on the inboard and outboard ribs, and front and rear spars. I would plan to use a similar number and type of fasteners as the 140A uses for a similar cover arrangement. I would also add some diagonal supports for the outboard tank rib to support fabric tension, similar to how Piper does it... Am I missing something. Yes I know I am fixing something that isn't broken, but IF I ever need to get to the tank..... Does anyone have a sample 337, or field approval that I could get a copy of for this mod? If anyone knows the N# of a 140 with this mod, I can order a CD of the paperwork from the FAA.
Thanks for any help
John Groeneveld
N76256 four years into a total restoration
Thanks for any help
John Groeneveld
