Carburetor Overhaul
Posted: Sun Nov 12, 2023 4:24 pm
by 6553
Could someone clarify if it is necessary to drop the oil tank on C85 engine to access the right rear attach nut on a Stromberg carburetor? Alternately, is a special wrench/socket needed. Access is extremely tight and requires safety wiring. Thanks
Re: Carburetor Overhaul
Posted: Sun Nov 12, 2023 6:34 pm
Remove the carb with the intake spider. Easy to work on on the bench.
(Disconnect the linkage and primer line, and slide the rubber tubes off the spider and up the intake tubes. Then, two nuts to drop the spider with the carb.)
Posted: Sun Nov 12, 2023 10:21 pm
by 6553
Thanks for information. Your approach makes the most sense to simplify access and allow proper safety wiring.
Posted: Mon Nov 13, 2023 8:19 am
by tonycondon
yep removing the spider is the way lol.
