				Dow Corning 4 Electrical Insulating Compound
				Posted: Thu Nov 30, 2023 4:40 am
				So I'm working on my Ford Ranger multi-function turn signal and I see there is a bunch of grease all over the internal copper contacts.  Reminded me that I have a tube of Dow Corning 4 in my hangar that an A&P had me buy years ago and I don't recall what it's purpose is.  I think he said to use it on the silicone parts of the ignition harness?  I figure it's non-conductive.
				Re: Dow Corning 4 Electrical Insulating Compound
				Posted: Thu Nov 30, 2023 8:06 am
				It's called "dielectric grease".  Used to lubricate and prevent corrosion (by excluding moisture) on switches, connectors, light bulb sockets, etc.  It is non-conductive in that it won't short all the pins on a socket together, but it will not insulate an otherwise good connection, either.  Your A&P may have wanted you to use it on the connections between the ignition wires and the spark plugs.
				Posted: Thu Nov 30, 2023 12:22 pm
				Ah, that makes sense.  The old Aero-Lite ignition harness was a little tight on the plugs.  My overhaul with new Kelly wires aren't so tight so I never thought to use the stuff.  Thanks!
