Key switch '46 panel
Posted: Thu Feb 29, 2024 5:46 pm
Was looking at a little extra security on my bird, thought about changing out the Master toggle switch to some sort of key switch.
Here's what I have...
Here's what I'm looking for (not this cheap Amazon chinese special, a real milspec one). Any ideas? Searches turn up nothing so far.
I do put a throttle lock on the bird when I'm parked away on the hamburger flights or when I'm not immediately around it. I know it's not a cure all but it's a simple thing to do if I can find the right key switch. Don't want to go through the effort of the mag/master switch, it'll make a bigger hole....
Re: Key switch '46 panel
Posted: Thu Feb 29, 2024 6:16 pm
Get a cobra motorcycle lock and wrap it around the prop.
Locking the master will only prevent them from using the radio. Flip on the mags and hand prop it.
Posted: Thu Feb 29, 2024 6:19 pm
Agreed. Just another layer. Anyone can cut the p-leads also.
Posted: Fri Mar 01, 2024 10:55 am
by 8281
Just install an Aircraft approved Keyed Switch !
Every position will work except the Start position !
If You want one, I have one for sale!
Posted: Fri Mar 01, 2024 10:59 am
by 8281
I meant to say Aircraft Keyed Mag. Switch !
