Fuel Dip stick Measurements
Posted: Mon Aug 20, 2018 9:10 pm
by 8302
Hi, somewhere in one of the news letters there was an article on how to calibrate a fuel dip stick with measurements. Does anyone recall that?
Re: Fuel Dip stick Measurements
Posted: Mon Aug 20, 2018 9:31 pm
There probably was, but, if you can't find it, don't let that stop you. It's pretty easy.
1) drain tank.
2 put in a known quantity of fuel.
3) mark stick
4) repeat from step 2 as necessary.
Posted: Tue Aug 21, 2018 6:53 am
by 8264
I have a copy of the measurements, I think I found them on the forum before it was updated. Not my work but i copied and pasted it below:
I calibrated a fuel dipstick using an ordinary wooden 12" ruler. Here are the numbers. This was done on a level hangar floor. Scott 3200 tail wheel, 6.00x6 tires. Best to empty your tank and start out by putting in exactly 4 gallons. Stick the tank, mark the stick. Then add a gallon and stick the tank, mark the stick, etc. etc. Note the reading on your fuel gauge as you go if you want to, but remember it will not read the same in the air.
6" = 12+ gallons
4 1/2" = 11
3 5/8" = 10
3 1/8" = 9
2 1/2" = 8
2 1/8" = 7
1 3/4" = 6
1 1/4" = 5
7/8" = 4
Posted: Tue Aug 21, 2018 8:03 pm
by 8302
Thank you for your replies.
Posted: Tue Aug 21, 2018 8:22 pm
by 6339
The above measurements are very accurate. I used a paint paddle with these markings on my '48 140 and it's usually within half gallon when I refuel
Steve Rose
Posted: Tue Oct 02, 2018 10:10 pm
by 8279
Will these measurements hold true for the “A” models as well?
