CHT/EGT Indication setups
Posted: Mon May 06, 2024 2:33 pm
by matthewhinmann120cm
Hello all,
What is everyone using for CHT/EGT indication? I currently don’t have anything installed in the plane and would like to get some kind of EMS system to monitor EGT/CHTs. What are you all using if any?
Matt
Re: CHT/EGT Indication setups
Posted: Mon May 06, 2024 7:36 pm
by rominoff
I'm like you, nothing, nada, zip on the little c85-12.
Posted: Tue May 07, 2024 8:45 am
by 8413
I have an EGT on cylinder 1. I don't find it to be of much use. I find that leaning until it starts running rough then richen till smooth works just fine and is quicker than watching EGT numbers on a gauge. I would rather have CHT on the hottest cylinder if I wanted to monitor anything.
Josh
