'47 C120 - Lost braking
Posted: Fri May 31, 2024 8:11 pm
Our right brake went inop during the after-landing roll last night. Once we cleared the active, I looked in the footwell, and saw that the piston rod in the left brake cylinder had deattached itself from the rod end, on the top of the pedal. I threaded it back up with my finger, which got us back to the hangar, and then I tightened the check nut back up, which hopefully has gotten us back in business.
Other than periodically inspecting that assembly during pre-flight, and ensuring brake pressure before landing, is there a way to prevent that rod from backing itself out of the clevis? There is no safety wire, split washer, or anything like that, I noticed.
Sure made for an exciting landing roll
Thanks!
Thanks!
