Large door frame gap in flight
Posted: Thu Feb 06, 2025 9:05 am
'47 C120
Cold weather question ... we've noticed that our airplane leaks quite a bit of air around the top of the door frame, as the aft side pulls out, exposing a 1/4" gap during flight. This is not the case on the ground (I'm sure, in flight, the pressure difference/Bernoulli principle "pulls" the top of the door frame outward - leading to quite a bit of cold air leaking in). We're in the Northeast.
Question: has anybody seen this? How did you address it, with maybe some sort of an additional "latch" at the top of the door, to keep the door frame flush with the fuselage?
Thanks!
v
Thanks!
v
