Pulling by the tail wheel.
Posted: Tue Jun 10, 2025 10:51 am
by bc12d
Just a question for those, who pull there Cessna 140's by the tail what type of puller are you using they have tail wheel pullers on Aircraft Spruce's site, but they are pricy, we used to use at a club I belonged to a tail wheel hook that hooked over the the arms of the tail wheel that hooked to the rudder springs, and we used it for years but Im sure it wasn't good for it.
Re: Pulling by the tail wheel.
Posted: Wed Jun 11, 2025 12:03 am
by dcannon
Agreed that the Taildragger Dragger is expensive. But it works well and you only buy it once.
I cannot imagine pulling the airplane by the tailwheel steering assembly. That sounds like a disaster waiting to happen.
Posted: Wed Jun 11, 2025 7:50 am
I have a tailwheel tow bar. They were available from Wag Aero. Not sure if ACS has them now. I don't use it very often. I just loop a rope around the tail spring, break the tailwheel free and pull it around that way. Another loop in the free end (tie a bowline) makes a good handle. Cheap and effective.
Posted: Wed Jun 11, 2025 8:52 am
6643 wrote: ↑Wed Jun 11, 2025 7:50 amNot sure if ACS has them now.
Yeah, they do, and boy have the prices gone up! I think it was about $50 when I got it.
Posted: Wed Jun 11, 2025 9:21 am
by bc12d
Yes the tail wheel tow rigs are quite a bit from ACS, I think I like the idea of just rapping a rope around the tail spring and pull it. Not the best but it will work, when I belonged to a group that had a C140 someone in our group bought a pull out handle that was placed on the side of the fuselage , and it worked quite well , I do not know where it was purchased from though.
Posted: Wed Jun 11, 2025 11:47 am
by 6183
bc12d wrote: ↑Wed Jun 11, 2025 9:21 am Yes the tail wheel tow rigs are quite a bit from ACS, I think I like the idea of just rapping a rope around the tail spring and pull it. Not the best but it will work, when I belonged to a group that had a C140 someone in our group bought a pull out handle that was placed on the side of the fuselage , and it worked quite well , I do not know where it was purchased from though.
That handle is from B.A.S.
https://basinc-aeromod.com/tail_pull_handles.php
More expensive than the tow bar, but those that have the handle mod installed say it’s really nice.
Posted: Thu Jun 12, 2025 11:34 am
by 8475
Can confirm that his handle is well worth it. A previous owner installed it in my plane and it is a huge help. One of the best quality-of-life mods you can make.
Posted: Sat Jun 14, 2025 11:11 am
by bc12d
Thanks for all the reply's . The Handel on
the fuselage sounds like a winner.
Posted: Tue Jun 17, 2025 10:31 am
by 8014
We used the towing strap method when we first got the C120. Then, my wife got me a Taildragger Dragger and I have not regretted having it ever. At $268, it's more affordable that the handle ($365+installation), and you don't need an A&P to assemble it. ;)
Tony
