ADSB Out Issues Resolved
Posted: Mon Jun 23, 2025 7:57 am
I've had intermittent issues with ADSB out failures over the past 5 years. It has been a long and complex nightmare and at times I was just about ready to pull my hair out. But, I finally got everything resolved. The journey included everything from a new voltage regulator, changing from a Uavionix Tail Beacon to a Stratus ESG...wire and switch replacement, cleaning up grounds, changing out anti-collision lights...ad nauseam.
A couple key (and elusive) points for those that may be experiencing similar issues:
1. Do NOT install a non-shielded USB charger in your airplane. It will blast the transponder.
2. If you have a secondary GPS antenna like I do for my GNC250 NAV/COM, and if it fails, it can blast all other GPS antennas including a Sentry or Stratus ADSB IN receiver and a WAAS antenna if you have a panel mounted ADSB/Transponder like the ESG.
Obviously there are other potential issues that may need to be addressed, but these were two biggies for me. Thought I would share.
