Searching for a starter clutch
Posted: Tue Oct 14, 2025 2:16 pm
by alexallen
I am still using the Delco pull starter and am in need of a replacement clutch. Anyone have an idea where I can get one?
Re: Searching for a starter clutch
Posted: Tue Oct 14, 2025 5:26 pm
https://niagaraairparts.com/
Niagara Air Parts used to be the go to for the pull starters but they aren't advertising it anymore. Don't know if they still service them on the side or not. All I can suggest is to contact them and see.
Posted: Tue Oct 14, 2025 6:39 pm
by tonycondon
my understanding is Niagara is no longer making clutches. they are not servicable in the field, so as they start failing, we all will be switching to light weight starters I guess
Posted: Tue Oct 14, 2025 6:55 pm
tonycondon wrote: ↑Tue Oct 14, 2025 6:39 pm my understanding is Niagara is no longer making clutches. they are not servicable in the field, so as they start failing, we all will be switching to light weight starters I guess
Yup, this is a "tuff one". I get a couple calls a year on this issue and so far have been un-able to find a source..........
Posted: Tue Oct 14, 2025 6:56 pm
alexallen wrote: ↑Tue Oct 14, 2025 2:16 pm I am still using the Delco pull starter and am in need of a replacement clutch. Anyone have an idea where I can get one?
Did you check "marketplace"? Someone in Ohio has a couple of "pull type starters"
Posted: Wed Oct 15, 2025 7:36 am
by 6898
I have a couple 815 695 9970 weekdays
