Fuel Primer
Posted: Wed Apr 08, 2026 11:38 am
by 46cessna140
My original 1946 C140 Imperial Brass fuel primer leaks. Feedback on replacing the leather plungers (if available or if they can be made successfully) versus updating to a modern o-ring style primer would be appreciated.
Re: Fuel Primer
Posted: Wed Apr 08, 2026 2:33 pm
I made one from the leather of an old wallet. Don't ask me any questions, though, as it was about 35 years ago. Still works, though!
Re: Fuel Primer
Posted: Fri Apr 17, 2026 1:54 am
by 46cessna140
I will look into making plungers. Thank you.
Re: Fuel Primer
Posted: Fri Apr 17, 2026 8:20 am
by 8413
Not sure if this is the same primer you have, but here is a Youtube video on making the leather seals for an Imperial fuel primer in a Stinson..
https://youtu.be/DshwmMKmTj8?si=DCp-qTvPDFTyUbDG
Josh
Re: Fuel Primer
Posted: Wed May 13, 2026 12:42 pm
by carll
I had the same issue on the same style of primer. I just disassembled and massaged the leather seal with ez turn lube. So far so good. I think they only leak because they dry out over long periods of inactivity. I like the video shared below on how to make new seals, try that next. Let us know
