Wheel Pant Alignment and Cutout
Posted: Fri Nov 23, 2018 4:14 am
My C140 Project came with a pair of fiberglass wheel pants that resemble the vintage aluminum ones for our our aircraft, but they need to be measured and cutout for the mounting pltes to fit around the landing gear spring steel and Cleveland brakes. A few years ago, I bought the Lahti Aerospace carbon fiber mounting plates and longer axle nuts from Matt Lahti, so I am set for parts, but I am working through in my mind the process of how to center the wheel in the pants. I figure if I can get an axle center on each side of the pant, then I can locate the center of the mounting plates using the center of the axle bolt pattern before I cut the relief for the mounting plate. I have examined many photos of pants on C140s, so I know approximately where the axle center is with respect to base of the wheel pant.
Has anyone ever done this from scratch, and if so, I would be interested to know about what kind of fixturing you used? I was planning on blocking the wheel and tire on three sides (front, back, and top) with the axle and long axle nuts installed and extending center lines from each side by making some threaded pins with points that I can adjust outward to touch on the inside of the pant. Once I have these center points, I can drill pilot holes from the inside of each pant.
I have seen some setups on the Internet for the RV builders, but their pants are different.
Even if someone in this forum could provide me a couple of dimensions for where their axles centers on their pants would be helpful.
I am using standard 6:00 x 6 tires on Cleveland rims.
Thanks.
Tony
Thanks.
Tony
