Door Seals
Posted: Sat Nov 24, 2018 4:11 pm
by 8246
Happy winter... I think my cabin heat would be much more effective if the door seals were doing their job. Does anyone have any suggestions as to where to obtain door seals that can do the job?
Logan
N76372, 1946 C140
Re: Door Seals
Posted: Sat Nov 24, 2018 9:00 pm
by 6298
Tye Hammerle used to have them. Not sure if he still does.....
Re: Door Seals
Posted: Sun Nov 25, 2018 9:50 am
by 8342
Wag Aero sells it and probably Univair.
Re: Door Seals
Posted: Sun Nov 25, 2018 1:15 pm
I think the material from Univair and Wag-Aero is a generic seal and is not exactly right. Not sure how well it would work. The material Tye was selling is a duplicate of the original he had specially made. Next time I'm out at the hangar I'll look for his contact information, unless someone else pipes up first.
Re: Door Seals
Posted: Sun Nov 25, 2018 5:00 pm
by 4004
John C is correct, as usual. I think I saw Tye on here in the recent past. IIRC his material is/was bulk special made stock, so you cut to fit at installation. Let's give Tye time to come online, he may have residual stock he needs to sell, wasn't making money, just helping us folks. If you'll don't hook-up shortly, I'm sure I have an order of his in my hangar stock that I can make available at cost.
contact info: tye@Leakpath.com from an older membership book (just don't tell him I told you) :D
Big Edd
moxcart1@wmconnect.com
Re: Door Seals
Posted: Sun Nov 25, 2018 5:22 pm
by 8233
I'd be interested in some material as well.
Re: Door Seals
Posted: Sun Nov 25, 2018 8:30 pm
by 8322
I too may be interested! But then again mines the heat will cook you out so maybe bad door seals are good CO insurance! Lol
Re: Door Seals
Posted: Thu Nov 29, 2018 7:26 am
by 5806
The seals Tye was having made work very well, as the original design was intended. I used them on mine.
Mention the word "Stearman" and maybe Tye will show up. ;)
Re: Door Seals
Posted: Fri Jan 18, 2019 10:19 am
by 8340
I emailed Tye, he replied, I sent him money, he sent me door seals. I have installed them on the right side door and now have the seal clamped under some wood to hopefully make it lay more flat. It's nearly impossible to close the door right now but I'm sure that will change as soon as I warm them up and have them set flat for a while. They are an exact reproduction from what I can tell.
Joshua
Re: Door Seals
Posted: Fri Jan 18, 2019 10:39 pm
by 6183
Bill Rhoades also had a run of the original seal made that he sold to members several years back. He may still have a supply of the seal material available. His address is in the membership book.
