Page 1 of 3
Glide Ratio
Posted: Wed Dec 05, 2018 10:46 pm
by 8337
What is a C-140’s glide ratio?
Re: Glide Ratio
Posted: Thu Dec 06, 2018 12:24 am
by 6896
Unlike the later Cessna models, the C140 POH is rather sparse for technical data, including glide ratio data. However, the C140, C150, and C152 all used the NACA 2412 airfoil. Since the wing generates significant drag (because it generates significant lift), I would think the C140's glide ratio approximates that of the C150 and C152, which is about 9:1.
For reference, the NACA 2412 section L/Dmax of the plot for lift coefficient vs. drag coefficient is about 88:1 at Re = 3,000,000 (Re calc based on assumption of 60 mph best glide speed), but this is just for the two-dimensional wing (REF: Abbott & Von Doenhoff, Summary of Airfoil Data, NACA Report 845, 1945).
Re: Glide Ratio
Posted: Thu Dec 06, 2018 6:52 am
by 8337
Seems like as many 120/140 s that are out there Cessna would have an updated POH
Re: Glide Ratio
Posted: Thu Dec 06, 2018 1:22 pm
8337 wrote: ↑Thu Dec 06, 2018 6:52 am
When the plane was certified, the only requirement was a one page "manual" Form ACA-309. The fact that there is a manual at all is unusual for planes of the era. Cessna added the manual in 1947. See Cessna Service Letters SLN-32 and SLN-40. Here's my ACA-309.
- Form ACA-309.jpg (226.38 KiB) Viewed 15270 times
Re: Glide Ratio
Posted: Fri Dec 07, 2018 7:52 pm
by 8337
That’s pretty cool. ForeFlight seems to think the glide ratio is 10:1
Re: Glide Ratio
Posted: Fri Dec 07, 2018 8:30 pm
That may be possible, but I suspect, in the real world, it's pretty optimistic.
Re: Glide Ratio
Posted: Mon Mar 21, 2022 2:48 pm
by maverick_fa
6896 wrote: ↑Thu Dec 06, 2018 12:24 am
I apologize for my ignorance... how did you came up with that conclusion. I got this approx. glide ratio from the POH
C150 = 8.5 (14NM / 10k')
C172 = 9.1 (15NM / 10k')
C152 = 9.7 (16NM / 10k')
Re: Glide Ratio
Posted: Tue Mar 22, 2022 10:33 am
by 6183
Or you can do a little testing
Horizontal Distance Traveled
Change in Altitude in Feet
Divide the Distance Traveled by the Altitude Loss
For example:
5 miles Traveled with a loss of 3,000 Feet
(*change the distance of 5 miles to feet-26,400 feet)
Use the formula - 26,400/3000=Glide Ratio of 8.8
Therefore, if you lost power at 3,000 feet you will travel approximately 9 feet for ever loss of 1 foot
If you experiment with the aircraft at different weights remember that the glide ratio will be approximately the same, but at a heavier weight the glide will need to be made slightly faster. Wind will also make a difference; therefore, you can experiment with different indicated airspeed values in different amount of wind, i.e. 0 - 10 knots for example, to see how much distance you an can cover. You probably will find that around 65-70 mph will give you a pretty good glide ratio.
Re: Glide Ratio
Posted: Wed Mar 23, 2022 12:10 pm
by a64pilot
maverick_fa wrote: ↑Mon Mar 21, 2022 2:48 pm
Interesting numbers I’m skeptical because a 150 is a lot less draggy airframe than a 152. That omnivision rear window is a lot of drag. The 150 ought to have a better glide ratio than the 152.
Just realized newer 150’s had the window.
The 140 ought to have the least drag as it has no nose wheel and a lower drag fuselage (no rear window). it’s not the window, it’s the shape.
Re: Glide Ratio
Posted: Thu Mar 24, 2022 4:07 pm
by maverick_fa
a64pilot wrote: ↑Thu Dec 06, 2018 12:24 am
Take a look at the POH
