replacing side windows
Posted: Thu Jan 03, 2019 9:03 am
by 6656
I need to replace the side windows, the plexiglass is in poor shape. Suggestions as to how to do that?
Posted: Thu Jan 03, 2019 9:06 am
by 6656
Probably should mention it is a 1946 C 140
Re: replacing side windows
Posted: Thu Jan 03, 2019 3:28 pm
by 8231
Door or rear windows?
Re: replacing door windows windows
Posted: Fri Jan 11, 2019 4:56 pm
by 6656
The door windows Plexiglas is in poor shape on a 1946 140. How do I go about fixing that. Replace the whole window or take off the frame and replace the plexiglas?
Posted: Fri Jan 11, 2019 7:13 pm
The frame is removable, then you can replace just the plexiglass.
Posted: Sat Jan 12, 2019 9:35 am
You have to drill out all the rivets around the edges.
Posted: Sun Jan 13, 2019 10:09 am
by 8233
6643 wrote: ↑Sat Jan 12, 2019 9:35 am You have to drill out all the rivets around the edges.
John, I was looking at mine the other day and considering replacement as well and saw those rivets. From a tool perspective, how do you get new rivets in there? It just doesn't seem like there would be any room to work with a rivet gun and bucking bar. I'm sure there's a solution, I'm just ignorant to what that would be.
Posted: Sun Jan 13, 2019 7:23 pm
by 5115
8233 wrote: ↑Sun Jan 13, 2019 10:09 am
Pretty easy to do with a 'Rivet Hand Squeezer'. Check Spruce for different models. Did my windows and it was not very difficult.
Posted: Sun Jan 13, 2019 10:31 pm
by 8233
Ahh, thanks! I knew there had to be something out there for that.
Posted: Mon Jan 14, 2019 8:57 am
by 6656
I've seen adds for "Bubble" type windows. Seems to me that it might have a distortion problem. Any experience with those?
