Uavionix Skybeacon
Posted: Wed Jan 09, 2019 8:10 pm
by 6741
Has anyone used the Skybeacon for ABS-B out?
If so, could I get a copy of the 337?
I just purchased one.
Stew Bowers N77114
Re: Uavionix Skybeacon
Posted: Wed Jan 09, 2019 8:43 pm
Doesn't it come with an STC? If so, the 337 is a no-brainer. The STC is approved data, so all you have to do is document the fact that it was installed IAW the STC. Done.
Posted: Wed Jan 09, 2019 9:39 pm
by 6741
STC for just about every Cessna ever made, but not for C120/140
Posted: Wed Jan 09, 2019 10:28 pm
6741 wrote: ↑Wed Jan 09, 2019 9:39 pm
FAA issued a "clarification"...best I recall it was in early (March?) 2016 & it reads (in their typical 1000 words or more) that ADS-B Out equipment which meets all of their certification hoops can be installed in certified aircraft that are not on the manufacturer's initial "STC list". This should be readily available to the IA. This is what we referenced on a 337 when installing the Garmin GDL82 which was then only "approved"/STC'd for Mooneys. It was not a problem. Since the SkyBeacon now meets all of the same requirements, the paperwork should be as simple as the 3-screw installation
Mac
Posted: Mon Jan 14, 2019 10:26 am
by 6478
Uavionix has a sample 337 you can use available here:
https://uavionix.com/downloads/skybeaco ... -Rev-D.pdf
Posted: Mon Jan 14, 2019 4:58 pm
by 1307
I already have Whelen wing tip strobes, so I'm waiting for the tailBeacan certification. Should be soon according to uAvionix. Expected 1Q 2019. Two screws, one power wire......couldn't be any easier.
https://uavionix.com/products/tailbeacon/
Posted: Mon Jan 14, 2019 5:01 pm
by 8359
1307 wrote: ↑Mon Jan 14, 2019 4:58 pm
Also waiting on the tail light variant. Unfortunately I think this gov shutdown is slowing their certification.
Posted: Thu Jan 17, 2019 5:36 pm
by 1307
I'm afraid you are right in that. Fortunately, the tailBeacon is a quick installation by any A&P. No waiting in line for an avionics shop appointment.
Posted: Fri Jan 18, 2019 9:56 am
I'm anxious to hear/read results of the first flight check report after an installation on one of "our" planes. With shipments having now been happening for a few weeks (...I understand that Spruce and other major sellers are totally back ordered) there's gotta be some making their way to some 120/140 wingtips? Mac
