License Plate Winterization Kit
Posted: Sun Jan 27, 2019 3:07 pm
				So a couple of months ago, I figured out that an old license plate is just barely big enough to cover the main vents on the cowling.  And the holes in the license plate happen to line up between the grills on the vents.  So I made a rough mock-up just to prove the concept.  I made a bracket that would go on the inside.  I figured you could put felt or any kind of rubber seal material on the license plate to protect the paint on the cowling.  And you could to the same with the bracket on the inside to prevent wear on the slats of the vents.  I still haven't decided on the best type of fastening system to attach the plate to the bracket.  Anyway, I thought I would throw the idea out there and let folks with more talent and more tools run with it.
Some other thoughts...
The license plate just barely covers the opening in the cowling, so getting it lined up correctly is important.
My license plate is pretty boring. But some states have colors or pictures that might go well with your plane.
Depending on what airports you visit, you might draw attention to your plane and be asking for a ramp check...
If anyone does give it a try, please post your photos for us.
