C-140A Tire Pressure
Posted: Sat Mar 02, 2019 5:29 pm
by 8156
Recently purchased a 1950 C-140A and would like to find out what the recommended tire pressures are. All are standard size tires and it has a Scott 3200 tail wheel.
About 90% of my flights are out of grass strips but I am starting to spend more time on hard surfaces.
Appreciate any advice...
Dennis
Re: C-140A Tire Pressure
Posted: Sun Mar 03, 2019 11:08 am
by 6339
I keep mine at 24 for the mains and 35 for the 3200 tailwheel. I operate almost exclusively on pavement.
Mine is a 48 with the forward swept gear.
Steve
Posted: Sun Mar 03, 2019 5:09 pm
I can tell you the 120-140 operation manual says 16psi, but I don't have a 140A operating manual.
I run 16psi in my 8.00's and primarily do wheelies on asphalt (I miss my old grass strip) with no extenders on early legs.
Posted: Thu Mar 07, 2019 8:46 pm
16-20psi on the mains.
35 on a Scott 3200 tail wheel.
I run 7:00 X 6 mains and fly off grass quite a bit.
Posted: Sat Mar 09, 2019 6:44 am
by 6277
There's a graph somewhere on TP for the Scott 3200. It's small and hard to read but is based on tail wheel weight. 30 works fine for me. I keep the mains at 27 or 28. When they get low (around 20) it's hard for me to push the plane out of the hangar with full fuel.
Posted: Tue Mar 12, 2019 1:21 pm
by 8170
16-18 on my 6.00x6 and 15-30 max on my 8.50s
