140A Fuel dip stick
Posted: Tue May 14, 2019 10:00 am
by 8401
Does anybody know where I can find a dip stick for a 140A? Will a dip stick for a 150 work?
Re: 140A Fuel dip stick
Posted: Tue May 14, 2019 8:16 pm
by 4390
viewtopic.php?t=232
You couldn't use a 150 stick since your 140 has a tailwheel and the 150 does not.
Posted: Sun Sep 20, 2020 12:33 am
by 8292
I use the 11" universal fuelhawk. I've run a tank to exhaustion ok two occasions and fueled the airplane a gallon at a time. I'm flying tomorrow, I'll try to remember to post my data.
John
Posted: Sun Sep 20, 2020 10:34 am
by a64pilot
All you need is a wooden dowel and mark it yourself.
However I learned to make it long enough that it can’t fall into the tank
Posted: Sun Sep 20, 2020 2:07 pm
by 6183
a64pilot wrote: ↑Sun Sep 20, 2020 10:34 am
Good point Jody,
Primary student of mine did that a few months ago, and had to fish out the stick with some mechanical fingers that I picked up at Harbor Freight. To prevent a repeat, I put two 8" tie warps set at 180 degrees to each other at the top of the stick. Now if anyone lets go, the tie wraps prevent the stick from going down into the tank. Just my 2 cents.
Posted: Tue Sep 22, 2020 11:53 am
by 7896
Here is my sheet for a C120 and the 11" universal gauge. Not an exact match, but maybe helpful.
Cheers,
