				Does anyone know if you can buy new fuel caps for a 1948  c140
				Posted: Fri Oct 04, 2019 7:35 pm
				by wichita140
				Need to replace my fuel caps on my 1948 Cessna 140. Mine have two vent holes in the top of each is this right???
				Re: Does anyone know if you can buy new fuel caps for a 1948  c140
				Posted: Fri Oct 04, 2019 8:32 pm
				by 6298
				It is right! I bought some a while back. I’ll see if I can find the part number in the next day or so.
				Posted: Fri Oct 04, 2019 9:12 pm
				by 6298
				These fit nicely. I haven’t drilled another hole yet, but. it will be easy. Part number is 05-01058 from Aircraft Spruce. Picture is too large..
				Posted: Fri Oct 04, 2019 10:49 pm
				Here's the picture:
				Posted: Fri Oct 04, 2019 11:04 pm
				by VIP620
				Posted: Sat Oct 05, 2019 6:04 am
				by 8342
				You need to read this posting in Neal Wright Technical Articles:
Mis-using gas caps on 140s that are meant for 140/120 planes
It will explain venting on each type of airplane and what type of gas cap you should use for each.
