Wing Strut Damage/Repair?
Posted: Wed Nov 27, 2019 2:08 pm
by 8024
JD C-140 Lift Strut-A.jpg (345.25 KiB) Viewed 7472 times
Good afternoon All--
Currently putting a 46 140 back together with a buddy and going thru all the pieces and parts. Please see attached photos of the wing strut attach point. It appears the original hole may have been to allow a tie down ring to pass thru (this photo shows the end of the LH strut where it would attach to the forward spar), but as you can see this hole has been damaged. Questions are this: 1. Is there a way to repair this/or does it need repair? 2. Is the structural integrity of the strut compromised by this damage? 3. If it can be repaired, who does this repairs and approximate cost to repair? 4. if this can't be repaired, and is damaged beyond repair, does anyone have any 46 struts for sale?
Thanks in advance for all your assistance.
Kind regards,
Todd Littfin
Smokin' Rivet Airparts & Salavage
1947 C-140 N4112N
1964 C-150D N4366U
Re: Wing Strut Damage/Repair?
Posted: Wed Nov 27, 2019 2:45 pm
Todd...not seeing the attachment(?). Mac
Posted: Wed Nov 27, 2019 4:47 pm
You are correct; that hole was threaded for a tiedown eye.
It may be a standard AN or MS fitting. Some fittings are numbered NAS354 - NAS362 but I don't know if you'll find the right one in there. If not, Univair makes replacement struts. I would contact them and see if you can purchase that fitting, then have a good welder put it in for you. Note that the angle of the bolt hole is critical as is the overall length from the bottom hole to the one in the fitting.
Posted: Wed Nov 27, 2019 9:43 pm
by 8281
I have two wing struts for sale for the 46' C-120 / 140 . Do You need the left or right strut ?
I'm located in Alabama ! " Roll Tide" !
Thanks John
Posted: Mon May 25, 2020 6:25 pm
by ronaero
I need the left early strut sn 9813.
