Which tire size.
cubrath
Which tire size.
My new to me 140 has a well worn pair of 8.00x6 tires. Need a new set and wondering if I should switch back to the 6.00 X 6. I will be doing a lot of training in it for my son over the next year. We have nice firm well kept grass. Should I save the weight and go with the 6.00??
8322
- Name: Raymond H
Re: Which tire size.
I have 800s and I really like them, though up front I will tell you that is the only way I know her... I think they make the plane look beefier without looking like oversized bush tires..
What I have heard too, though remember its not first hand knowledge but it make sense.... The 800s ran at around 20psi offer a bit more cushion than 6.00s to give a little more forgiveness on landings with the stiff spring gear we have...
8187
If the weather clears up I’m going to go fly with a friend that has 8s.on his 140. He wants to try my 6s and I want to try his 8s. Will report back when it happens.
I tried 7.00’s for six months or so. I went back to 6.00x6’s and like them much better. You can see over the nose easier and the attitude seems right for full stall landings. Also, recently removed 8.00’s from a customers 140, so he could put the wheel pants back on, and he reports he likes them better.
