Alaskanized Cessna 140
Posted: Wed Nov 04, 2020 11:00 pm
by 8376
1948 Cessna 140: $33,000
N1044G/Serial #14403
AFTT (~5,623), EW (974 Lbs), Useful Load (476 Lbs), Max Gross Weight (1450 Lbs)
Complete, organized Logs back to 1948 from Wichita, Kansas factory. NO Re-curring ADs!
Engine:
-Continental C85-12F Stroker, SMOH~450.
-Strong performers, burns little to no oil (less than 1qt per 25 hours).
-2019 Cessna 150 Exhaust (with appropriate braces) new in 2018
-2019 new #4 millennium cylinder
-2019 new spark plugs, magnetos, ignition harness
-2019 new MA3-SP carb
-2019 steves gascolator
-2020 new ignition switch
- Compression #1 75/80, #2 77/80, #3 76/80, #4 74/80
Body:
-Wings recovered in 2006 with poly fiber, still in amazing condition.
-Gear boxes repaired in 2020 by F. Atlee Dodge (NDI paperwork supplied)
Electrical:
-All wiring replaced in 2018
-All fuses replaced with circuit breakers
-New plane power alternator
-Garmin dual USB plug
-Garmin GTR200B radio
-Sandia Aerospace STX 165 transponder
STC’s:
-80/87 Autogas
-Rosen Visors
-Plane Power 50amp Alternator
-Spin-on Oil Filter (oil screen desoldered, not necessary to remove at oil change)
-Reiff XP Pre-heat System (Oil Sump + Cylinder bases)
-Float lifting eyes
-Dual Hooker harness
-Steve's Gascolator
-Cleveland wheels and brakes
-Poly-fiber
-O200 Crankshaft
337’s:
-gear box overhaul
-Field approved 8.50x6.00
-new lower fuel lines and Sierra Hotel Fuel Selector
-BAS tail pull handle
-ACK E-04 406 ELT
-Scott 3200 Tailwheel
Accessories Included:
-Two sets of Alaska Wing Covers (one set with spoilers)
-Engine Blanket
-Windshield Cover
-Two Sets of elevator covers
Amazing plane and has been a great flyer. Only selling as I will not be flying it for the next two years. She loves the cold and performs great. Dress appropriately and you will have no issues in -20F. Only piece that has not been replaced under the cowl is the starter.
Flies straight, no issues in a crosswind with the right pilot, been all over Alaska, she loves to keep flying, help me find her a new home.
Text James at 407-221-6514 for pictures (all the ones I have are to large to post here). Or email kirsch.james@gmail.com
Appreciate your consideration, please pass to your friends.
James
Re: Alaskanized Cessna 140
Posted: Tue Dec 15, 2020 7:10 am
by 8376
SOLD
Thank you everyone, it has been a great trip.
