For Sale Bendix King KT74 Mode S Transponder
Posted: Tue Dec 15, 2020 10:16 pm
by 6930
I pulled this unit from my airplane and had a Stratus ESG Transponder and a WAAS GPS antenna installed for ADSB Out compliance. The unit works perfectly and has never failed a transponder check. It was bench tested and yellow tagged when removed a couple of days ago. "Glass" panel is excellent. No scratches or marks of any kind. A couple of the buttons show very slight (and barely noticeable) signs of normal wear. Case has the usual scuffs from inserting in the tray.
If you already have a KT76 installed, this will go right in the existing tray with no mods required (that is how I had it installed in my 140).
The transponder, maintenance release (yellow tag), tray (new, never used), install kit (new, never used) handbook and misc paperwork included. I just listed it on eBay today. Full pictures and details here: https://www.ebay.com/itm/193805146846?ul_noapp=true
I'm asking $700 on eBay but would consider less for a 120/140 member purchasing through this site.
Drop me a PM or give me a call at 630-606-3692. If you are close to Chicago, I'd be happy to bring the unit to you.
Mike Pastore
