Wanted C90-12 / Propeller
Posted: Sat Aug 27, 2022 2:38 pm
by intoaircooled
I'm looking to replace a C85-12F in my Cessna 140 that I purchase a couple of years ago. I'm trying to get if flying again but found a lot of rust on the cylinder walls, guess that's to be expected after sitting around for 15 years. If anyone can help me out or point me in a direction that would be great.
Thank you
Carl Benda
Re: Wanted C90-12 / Propeller
Posted: Tue Aug 30, 2022 11:20 pm
by beaverbill
I do have a C90-12 that I will sell. Zero time since overhaul a number of years ago. Just haven't found a plane to put it on yet. Feel free to send me a message if you are interested. Bill
Posted: Fri Sep 09, 2022 6:49 pm
by beaverbill
Carl, Did you receive the private message I sent you? I can't tell from the mailbox.
Bill
Posted: Fri Sep 09, 2022 7:12 pm
beaverbill wrote: Fri Sep 09, 2022 6:49 pmDid you receive the private message I sent you? I can't tell from the mailbox.
When you send a message, it remains in your "Outbox" until someone reads it. If it appears in your "Sent" messages it has been looked at at least once.
Posted: Fri Sep 09, 2022 11:50 pm
by beaverbill
Roger that. Thanks John.
Posted: Sun Dec 25, 2022 12:50 pm
by intoaircooled
Bill,
Sorry for not getting back to you on the engine, I go distracted with life and haven’t been on the site much. I did spend some time on the 140 yesterday and I did find a C-90-12F. I would have saved some money had I seen your post first. Anyway now I am in need of a rudder, the skin is bent both sides and the bell crank is looking pretty rough and the NAV light riv nuts are both gone. So if anyone has a good one they are willing to sell i’m interested
Carl Benda
Posted: Wed Dec 28, 2022 10:39 pm
by beaverbill
Carl,
There is a chance that our Chapter has a rudder. I will check this weekend on that.
Bill
Posted: Thu Dec 29, 2022 4:04 am
by 8224
I just finished the restoration of a C-140 that had been over on its back and of course needed a rudder. I found they are as scarce as hens teeth! I had the old crumpled up rudder so salvaged the tail light fittings and the bottom rib with the control arms. Bought a new spar, two side skins, and the top cap and had a “new” rudder with about 4 hours work. I bought the parts from Univair. I have several pictures if you want to see the procedure.
Steve Hawley
hluther205@gmail.com
Posted: Thu Dec 29, 2022 3:19 pm
by 8342
The skins and horn are available from Univair like Steve mentioned.
It is not hard. I replaced them on mine when I restored the airplane.
I did make a custom bucking bar for the rivets in the Spar.
The rivets on the trailing edge can all be done with a squeezer.
Posted: Fri Dec 30, 2022 8:54 pm
by beaverbill
I checked today and sorry but no rudder. We do have a set of elevators though.
Bill
