Sold: 1946 Cessna 140
Posted: Thu Mar 27, 2025 9:08 pm
by hotrodmac
Well cared for 1946 Cessna 140 looking for its next caretaker. This is a very clean aircraft with tasteful upgrades. Cruise to breakfast at 100 mph on less than 5GPH, or pull it back for some low and slow with your elbow hanging out the window at golden hour. $43,000
  • C85-12F 277 SMOH in 2019
  • Lightweight starter and alternator conversion
  • C150 exhaust, spin-on oil filter, winterization plates
  • BAS pull handle
  • C150 seats, Airtex interior, Hooker harnesses
  • Cleveland wheels & brakes, Scott 3200 tailwheel
  • Metal wheel pants and backing plates included, but not installed
  • PolyFiber wings with matching Imron paint, LED lights
  • Stratus ESG transponder with ADSB out
  • AV-30, I-Com A200, ACK 406 ELT, Sigtronic intercom, USB power ports
  • Logs available on request
  • Hangared KRUQ, Salisbury, NC
  • Currently flying so times will change
The inside cover of the airframe log has the following narrative about the airplane. I am not John Ausley.
Nov 2018 - All logs to N76926 are lost. William C. Murphy, from Dolan Springs, Arizona started restoration about 1980. He overhauled the engine in 2006 under the direction of an IA. The engine was pickled and was not run until October, 2011. He epoxy coated the interior of the hull. He also painted the aircraft hull with C 120 Yellow Poly Fiber paint. Not sure how many years he worked on the project. When I purchased the project it had 1140 hours on the tach, I have no reason not to believe that is the total hours on the airframe. When he died the project was purchased by Colfax Motors in Las Vegas, NV, and the project and moved it to C. P. Aviation in Santa Paula, CA. C. P. Aviation did $16699.06 labor and materials to the project, including rebuilding the wings and painting with green epoxy primer. Both fuel tanks were rebuilt and new gauges were installed.. C. P. Aviation also replaced the control cables and pulleys and rewired the airplane.. Frank Motter, from Lancaster, California obtained the project from C. P. Aviation. I (John Ausley) purchased the project from Frank Motter in December of 2008.
Please send me a private message if interested.
IMG_6529 Medium.jpeg (147.69 KiB) Viewed 29845 times
IMG_9984@2x Medium 2.jpeg (70.7 KiB) Viewed 29845 times
Spec Sheet 2026-Mar.pdf
(3.18 MiB) Downloaded 1408 times
Re: For Sale: 1946 Cessna 140
Posted: Fri Feb 06, 2026 8:44 am
by VIP645
I would like to talk to you about the aircraft. I have a customer looking for a nice Cessna 120/140. Earl Evans 770-361-0137.
We are in South Georgia.
Posted: Sun Mar 01, 2026 5:32 pm
by hotrodmac
Updated March 2026 -- Still for sale
