Vacuum Instrument Installation Expert needed...
Guys:
I'm working on a plane with a 9" venturi powering a DG and Artificial Horizon. They're plumbed as in the top diagram. Suction gauge shows 6" +/-. The DG precesses badly and 2 different AH's are "inop". I'm thinking the lower diagram would be better. Any expert opinions?
Vacuum system.jpg (171.48 KiB) Viewed 14607 times
6863
Re: Vacuum Instrument Installation Expert needed...
Post by 6863 »
Mine is not the answer you are looking for but ... my airplane has as its single attitude instrument a T&B indicator which works well off of one small venturi. Preferring silence to the noise of a gyro spinning when I shut down, I leave it disconnected. :D
John Kliewer
You're a big help! (If it's disconnected, how do you know it works well? Or, do you mean it "meets expectations"?)
6863
Post by 6863 »
I know it works well because I connect it up in anticipation of my annual inspection because that's the way my AI wants it, and I disconnect it sometime after. I bought the airplane to enjoy VFR flying only and do my IFR flying in something else much less fun. Like I said, mine was not the answer you would be looking for. Just thought I'd inject a bit of humor into the thread. Sorry if it falls flat for you.
John
John Kliewer
6641
Post by 6641 »
Suction instruments are normally plumbed in parallel with each instrument having its own unobstructed inlet line. Some have a gang filter some are individually filtered.
Your alternate diagram is correct.
You may not have enough suction as a 9 inch venturi for two large gyros is marginal. I doubt that you will even need the regulator. Try it and see.
Joe
8175
Name: Larry Lowenkron
Aircraft Type: Cessna 140A
Post by 8175 »
I was able to run a DG and AH off of a super venturi in my old plane (Bellanca Cruisair) since you couldn't run a vacuum pump off of a Franklin engine (not enough "holes" in the accessory case). The instruments were hooked up in parallel with no regulator. However, since I did fly the plane IFR, I had the venturi ice up twice (I am a slow learner!) so I moved it to a position in back of the exhaust. This pretty much eliminated the icing problem, but it actually reduced the amount of suction I could pull. While it was enough to drive the instruments (barely) I finally just removed the whole vacuum system and installed electric gauges.
Larry
6863 wrote: Fri Aug 17, 2018 12:13 pm Just thought I'd inject a bit of humor into the thread. Sorry if it falls flat for you.
No, I got the joke. Guess my joking response is what fell flat...
8175 wrote: Fri Aug 17, 2018 3:22 pmThe instruments were hooked up in parallel with no regulator.
So, the second diagram, minus the regulator?
I seem to recall some diagrams of vacuum systems in old Aircraft Spruce catalogs, or maybe Univair, but I can't seem to find one in my archives. Does this strike a chord with anyone? Anyone have more old catalogs than I (I just found one for Alexander's...)
6641 wrote: Fri Aug 17, 2018 12:45 pm Suction instruments are normally plumbed in parallel with each instrument having its own unobstructed inlet line. Some have a gang filter some are individually filtered.
Just got some more info from the previous owner. The system worked in it's current (series) configuration until he had a "hard landing" at which point the horizon quit. I (actually he) acquired a used (unknown) horizon which I installed and it doesn't seem to work, either. At this point I'm tempted to have the original overhauled, I just don't want to do that then find it still doesn't work...
To add insult to injury, the panel space is very limited, and I have actually tried to install 3 different used unknown gyros. The third one fit, but...
