120/140 Baggage Area
Occupation-Interests: Construction Consultant
RAF - MA/RI State Liaison (theRAF.org)
Post by 8349 »
Good afternoon everyone,
Can any of y'all shoot me a photo or two of the 120/140 baggage area, and or/the dimensions? I have flown one, and looked at several at fly-ins in my area, and have yet been smart enough to remember to get a good look at this area. The 140 is on my shortlist for a future purchase and I really like airplane camping, so just want to get an idea of the area I am working with for packing/planning, etc. I understand weight limitations, etc. Luckily, primarily a sea level pilot (say 10' to 2,000' elevations typically) and fly solo most often.
Thanks for whatever you help you can provide.
Esmiol
Aircraft Type: C120
Re: 120/140 Baggage Area
Post by Esmiol »
Drew, you can always drop by Salmon River when your out and about.
8424
Name: Steve A H
Aircraft Type: 1950 C140A
Post by 8424 »
Hi Drew.
Here's some info on the baggage area measured from the floor to the hat shelf.
Hat shelf to floor: 21 1/2".
Floor width: at rear bulkhead 24"; behind seat 31".
Floor depth: between bulkheads: 14 inches; from seat back to rear bulkhead 22-25 inches depending on position of seat back bottom.
Top width: 34" at rear bulkhead; 38" behind front bulkhead; between seat and front bulkhead; 33".
Top depth: 16-19" depending on position of seat back top.
My son and I flew our 1st 140 from interior Alaska to Oklahoma with the baggage packed full (no hat rack) with survival gear, food, baggage, etc. It will hold a lot of stuff!
Hope this helps.
Baggage 2a.JPG (173.13 KiB) Viewed 21658 times
Baggage 1a.JPG (11.56 KiB) Viewed 21657 times
8349
Post by 8349 »
8362 wrote: ↑Thu May 27, 2021 6:44 am Drew, you can always drop by Salmon River when your out and about.
Definitely need to pop in soon! Still have the 120 then? Where are you keeping the 182 - do they both fit in the hangar?
8349
Post by 8349 »
8424 wrote: ↑Thu May 27, 2021 8:37 am My son and I flew our 1st 140 from interior Alaska to Oklahoma with the baggage packed full (no hat rack) with survival gear, food, baggage, etc. It will hold a lot of stuff!
Hope this helps.
Awesome, thanks!
barrett5991
Aircraft Type: 1947 Cessna 140
Post by barrett5991 »
8424 wrote: ↑Thu May 27, 2021 8:37 am Hi Drew.
Hope this helps.
I second what he said. I dont have a hat rack installed on my 140 and it got me and all of my luggage from florida to utah with no problems. It certainly has more room than I actually need.
8349
Post by 8349 »
Thanks all, this has been quite helpful. And I assume the 120 is the same as the 140 for baggage area?
2356
Post by 2356 »
That would be correct.
Post by a64pilot »
If your wanting to carry weight, a 120 would probably be superior to a 140, because it’s lighter weight, or should be unless it’s been made heavy.
I would be looking for a light airplane, likely with an 0-200. Almost any mod or upgrade as most call them add weight, 150 exhaust systems, 150 seat etc all add weight as well as does of course metal wings.
A few lbs here and there add up, and very often people in trying to improve their airplane end up with a heavy one.
Depending on where you will be flying an airplane without an electrical system can be a whole lot lighter than one with, I mean a whole lot, and likely much cheaper too.
