Control Y install
hwdaviscfi
- Name: Herbert
- Occupation-Interests: A&P, CFI, CFII, MEI
Control Y install
I am in the process of restoring a 46’ 140 and I want to make a few modifications to mine. Has anyone installed a control Y in place of a T to do a center stack of radios? I am doing a new panel piece so I can cut all new holes and the control Y will drop the yokes in the panel 2” and I will put the yokes out of a 47’ in turned upside down.
Thanks for any input.
Re: Control Y install
I recall it has been done. I don't remember where I saw it, though. Should you decide to do it, I happen to have the part...
hwdaviscfi
- Name: Herbert
Thanks for the reply. I currently have both control Y’s. I have tried calling the local FSDO with no response back yet about doing a field approval. Trying to get ahead of it, but I am still currently disassembling wings and control surfaces to clean and prep everything with alumiprep-alodine-zinc primer inside and out.
Explain to them how it's functionally identical,it bolts on, and it enhances safety.
- Name: Huey Pilot
I had a friend that did this mod to his 140A. This was in the 70’s when it was easier to do mods.
N20JR, a 1949 140A has the “Y” installed. Also uses a Cessna 150A or B instrument panel in order to use center stack radio. FAA records indicated that George Cox in Memphis, TN owns the aircraft.
2356
- Name: Huey Pilot
This may very well be the plane. The mods were made at American Flyers in Oklahoma. They were a large flight school that operated 140s and 150s.
hwdaviscfi
- Name: Herbert
just an update on my control Y install. I have been in touch with a DAR and he says it is no problem for the sign off. the little 46 140 is getting a glass panel center stack.
What is the world coming to?hwdaviscfi wrote: ↑Sat Oct 23, 2021 8:00 pm the little 46 140 is getting a glass panel center stack.
