Eye bolts for rudder horns for tailwheel
flyer2017
- Aircraft Type: 140A
I need the eyebolts that replace the bolts that connect the rudder cables to the rudder horns and connect to the chains for the tailwheel. Is there a part number? My chains currently connect to tabs that are riveted to the horns but I'm reconditioning my 3200 tailwheel to stop the shimmy and thought I might go to the eyebolts as the tab holes are wearing. Thanks
flyer2017
Re: Eye bolts for rudder horns for tailwheel
Great! Thanks
- Name: Blaine F
- Aircraft Type: C140A
The Scott conversion requires the eye bolts.
- SCOTT_TAIL_WH_INSTAL.pdf
- (39.14 KiB) Downloaded 644 times
