C85-12 crankcase wanted or whole engine
matthewhinmann120cm
Aircraft Type: C120
Post by matthewhinmann120cm »
Upon pulling #2 cylinder due to no compression, I found a major crack in the center crankcase journal. If anyone has a C85-12 crankcase they would like to sell, or even a whole engine, let me know!
Re: C85-12 crankcase wanted or whole engine
It might be worthwhile to contact Divco. I believe in the past they either repaired similar issues, or at least took the case as a core.
matthewhinmann120cm
Aircraft Type: C120
6643 wrote: ↑Sun Nov 21, 2021 1:50 pm It might be worthwhile to contact Divco. I believe in the past they either repaired similar issues, or at least took the case as a core.
Thanks! Contacted Divco, and it seems like they will take my case as a core and exchange it for a repaired on. Awesome!
