PTT for the pretzel yokes
majourlittle
Post by majourlittle »
The previous caretaker of my 140 installed the pretzel style yokes and had made some nice PTT mounts that clamped to the yoke shaft and stuck out so that you could push the PTT with your non throttle hand. When my CFI got in the plane the first time, he broke one of them!
I decided that I really like the position of them but am not much of a woodworker and felt that a few things needed to be updated with the design. I created some new ones in CAD and 3D printed them to match the style of the fabricated ones, but are now much sturdier, thinner and dont slip around on the yoke shaft.
I would love to see how some of you mounted the PTT on your pretzel yokes.
nm taildragger
Re: PTT for the pretzel yokes
Post by nm taildragger »
majourlittle wrote: Mon Dec 06, 2021 8:15 pm The previous caretaker of my 140 installed the pretzel style yokes and had made some nice PTT mounts that clamped to the yoke shaft and stuck out so that you could push the PTT with your non throttle hand. When my CFI got in the plane the first time, he broke one of them!
That's nice work. How about a shot or two of the attachment?
Joel
“Mediocrity knows nothing higher than itself.” —Sir Arthur Conan Doyle
jimmie
Post by jimmie »
You have done a Great Job. Just bought a 46-140 with the sorry PTB anywhere you place it would be an improvement. I would prefer inside lower center as you fly with left hand. Please put my name in for two. Keep up the good work.
Jimmie
majourlittle
I don't have any good shots of the back, but I do have a shot of the model. The whole assembly is pinned together with two screws and imbedded nuts and the wires for the PTT stick through the little hole and go inside the pretzel yoke.
Not sure if they would be a big hit or not, but it would be around $50 ea + shipping If I were to do a batch run of these. Not terribly cost effective.
PTT Model.jpg (53.73 KiB) Viewed 5250 times
Post by edidin »
Would you be willing to share the model? I believe it could be 3D printed. I'd be happy to share a print or two in return. What PTT switch is used in the assembly?
I was in the process of designing a 3D printed mount to replace the ugly ones in my plane, but this is nicer.
majourlittle
You can see in my previous post that these are 3d Printed and that I have a calculated cost associated if you are interested in them!
Post by edidin »
Are they metal 3D printed then?
majourlittle
No, metal printing would make them $250 ea.
Post by edidin »
Thanks. This is similar to something was working on, thought you'd found a really cheap way to metal 3D print!
Post by edidin »
PLA printed design of PTT switch on pretzel yoke.
PTT Front View.jpg (89.04 KiB) Viewed 4872 times
