Rubber Pad for Tailwheel Spring Mounting #0442119
dtpilot
Aircraft Type: C120
Post by dtpilot »
I understand the 0442119 rubber pad is no longer available. Looks like I'll need to make my own. Can anyone here give me the dimensions of the pad?
Thanks!
hotrodmac
Re: Rubber Pad for Tailwheel Spring Mounting #0442119
Post by hotrodmac »
Pulled my old one out of the parts box. It’s not cut square, but 1.5in by 1.5in is what they look to have been going for. It’s 3/16” thick.
'46 C140
Aircraft Type: 48 140 C90
Post by 6898 »
Last ones i made had web reinforced materiel in the rubber .
dtpilot
Aircraft Type: C120
Post by dtpilot »
Thank You for the replies! I'll be replacing the main TW spring, and want to freshen up the installation with new hardware and rubber pads.
Cut them from the sidewall of a tire.
