I have Slicks, off right now for an alternator repair.
Anyway they are both Left mags, I assume that’s because they both have impulse couplings? Anyway when you pin them to set the mag timing to the engine, do you pin them both as Left mags? or do you pin the right one as a right mag?
Slick mags
- Name: Jody
Re: Slick mags
The "Left" refers to the rotation, not the position. And yes, set them both up as "Left (hand)".
- Name: Jody
Re: Slick mags
Thanks I figured that but wanted to be sure. I figured they both had to rotate the same direction due to the impulse coupling.
- 6898
- Name: Jeff T
- Aircraft Type: 48 140 C90
Re: Slick mags
Thank You John , Very helpful to our members needing the Correct Answers.
- Aircraft Type: C140-O200
Re: Slick mags
While there off you might do a little inspection just to take a gander inside and put a little green slick grease on the cam lobe, the new slick mags are now going for around $1200.00
- Name: Jody
Re: Slick mags
I’ll look into that
