Slick mags
Slick mags
Post by a64pilot »
I have Slicks, off right now for an alternator repair.
Anyway they are both Left mags, I assume that’s because they both have impulse couplings? Anyway when you pin them to set the mag timing to the engine, do you pin them both as Left mags? or do you pin the right one as a right mag?
Re: Slick mags
The "Left" refers to the rotation, not the position. And yes, set them both up as "Left (hand)".
Re: Slick mags
Post by a64pilot »
Thanks I figured that but wanted to be sure. I figured they both had to rotate the same direction due to the impulse coupling.
Aircraft Type: 48 140 C90
Re: Slick mags
Post by 6898 »
6643 wrote: ↑Tue Mar 01, 2022 4:49 pm The "Left" refers to the rotation, not the position. And yes, set them both up as "Left (hand)".
Thank You John , Very helpful to our members needing the Correct Answers.
phil123
Aircraft Type: C140-O200
Re: Slick mags
Post by phil123 »
While there off you might do a little inspection just to take a gander inside and put a little green slick grease on the cam lobe, the new slick mags are now going for around $1200.00 :o
Re: Slick mags
Post by a64pilot »
I’ll look into that
