Fabric clip installation
46cessna140
Post by 46cessna140 »
Suggestions on how best to install wing fabric clips would be appreciated. I am fearful of poking a hole in the new fabric using needle nose pliers. Is there a better installation method?
8224
Re: Fabric clip installation
Post by 8224 »
Just finished installing all the clips in the wings yesterday. My method is to install one end by hand and then pushing down on the center of the clip with thumb, give the upper end a whack with a small hammer, I use a 4 ounce ball peen. Usually have to hit it more than once. My thumb is still a little sore this morning! (From pushing the wire clip, not hitting my thumb with the hammer)
Steve Hawley
per ardua ad astra
Post by per ardua ad astra »
A friend of mine made a tool out of a piece of timber with a slot in it. Seemed to work really well.
Paul. Over to you!
7698
Aircraft Type: C120 - GAKVM
Post by 7698 »
As Andy suggests, I used a piece of timber approx 1.5" wide with a groove filed into the end to locate the clip... A rocking action easily pushed the clip in.
Without the use of the clip tool!!
46cessna140
Thank you! Following your method worked fine to install clips.
regular122
Aircraft Type: 1948 C140 C90
Post by regular122 »
I used a compass. You can set it to exact width and then tap the clips in. If the clips are very difficult, I used a piece of waxed string and pulled the bottom and then pushed in. See the thread below for pics. Steve
viewtopic.php?f=12&t=1137&start=100
