Door catch source?
Door catch source?
Anyone know where one can get new ones of the dual roller/spring catch fitted to the strut of a 120 to hold the door open?
- Door Catch Female.jpg (209.83 KiB) Viewed 4159 times
Re: Door catch source?
Try Home Depot. That's off a 1950's vintage kitchen cabinet door.
- Name: Ray Hunter
That will no doubt work, but the proper part is a strap that fits around the strut. The strap has "stud" on the end that pokes into an opening on the bottom of the door. Inside the hole is a friction catch that captures the stud. Check page 20 of the parts manual.
Thanks to both. After posted realized had seen as a kid on our old 1950s steel kitchen cabinets. Stock is the opposite apparently - catch through a hole in the door.
I have a bucket full of the catches. Free if you pay postage and handling
The strap is easy enough to make.
meloosifah
I could use a pair of those door catches if they are not going to be used! Both of mine are worn out.
greenwr400f
- Name: Mitch Spring
- Aircraft Type: C-140 & 172B
- Occupation-Interests: Retired Quality Control Supervisor with Textron Orlando.
A&P IA - Contact:
John if you have any more of those catch's I need a couple please.
